Oculus Quest Robot icon Oculus Quest Robot — Immersive Meta Quest VR control for Synthiam ARC robots: stereoscopic camera view, map servos to hands/controllers, plus built-in remote desktop. Try it →
Mobile App And Movement Panel(s)
Mobile App And Movement Panel(S)
So I have built a mobile app that works great. I have a custom Movement Panel set up in ARC that controls my robo claw "h-bridge"for movement of its tracks. For movement of my robots shoulders I have used a second robo claw as I have used wheel chair motors for those as well, and a third robo claw for body up/down using a linear actuator. The second and third roboclaw were easily used by using script commands in speech recognition. So in other words I can say robot raise right arm and his right arm moves.
Now the problem. I would like to add the shoulders, and body up down to my mobile app. It seems as though the mobile app works directly with a Movement Panel and unfortunately it seems I am only allowed one movement panel? I would also like to be able to control his head pan and tilt which operate off of "standard" servos. Any ideas how to get around this?
                                             Thanks          Chris
So I just created another one without coloring and mapping of individual buttons just in case it doesn't work again. I saved it to cloud. Again it said Saved! but nothing there. And yes Richard R this time I did save a copy to my desktop.
My mobile device says cannot open file. I tried to install the most recent ARC mobile. I currently have 2014 .5. 24. Not sure why it wont open this file. Thanks Chris
I keep trying to attach the file too but then this site crashes,weird. I rebuilt it with colors again although still incomplete and yes for sure I now save it on my computer.
There are no errors in our log for the website crashing.
Do you have the latest version of ARC for Windows and ARC for Android?
On your Android Device, are you loading your project from the Cloud or Local projects? If you delete a project from the cloud, it is still saved/cached on your device.
Just as an update.... Although I still cant make the cloud work, I was able to make the GUI on my PC and test it. From my PC all of the buttons work flawlessly. Now to get the mobile working would be great. One other question regarding this subject... As I add to my project, example when I finally add its claws is it possible to go back in and edit the CLoud GUI or do I have to recreate the entre project? Thanks
                             Chris
And my mobile device still says cant open for the newest mobile update! Chris
#15
Still working on this problem... Still cant attach file. Im willing to do a teamview with someone if there willing to help. Otherwise I could try attaching file to a regular email address provided someone is willing to share that also. Thanks guys!
        Chris
#16
One other question on this. I saved this project to the cloud many times now. From my pc shouldn't I be able to go to EZ-Cloud, OPen and be able to find my project? Its not there when I do this. Thanks again. Chris
