Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Mobile App And Movement Panel(s)
Mobile App And Movement Panel(S)
So I have built a mobile app that works great. I have a custom Movement Panel set up in ARC that controls my robo claw "h-bridge"for movement of its tracks. For movement of my robots shoulders I have used a second robo claw as I have used wheel chair motors for those as well, and a third robo claw for body up/down using a linear actuator. The second and third roboclaw were easily used by using script commands in speech recognition. So in other words I can say robot raise right arm and his right arm moves.
Now the problem. I would like to add the shoulders, and body up down to my mobile app. It seems as though the mobile app works directly with a Movement Panel and unfortunately it seems I am only allowed one movement panel? I would also like to be able to control his head pan and tilt which operate off of "standard" servos. Any ideas how to get around this?
                                             Thanks          Chris
#25
Another thing I just realized is when I launch ARC mobile from my galaxy 3 tablet there is not an option for EZ cloud app store, only Private apps, public apps, and local library. Again watched the video 10 times and that was the only thing I could come up with. The first app I made worked flawlessly over a month ago. I don't know what could have changed. Chris
#26
Yes, the private apps section is where you would download your app that you created.... Unless you marked it public, that's where your missing app should be... Not sure what you mean by cloud app store.... Your app should be in the private app section of your Android app (along with the public option, that is what we refer to as the cloud)...Are any of your other regular apps there? I have dozens saved and I can access all of them via my PC or Android (all from my private app space)
#27
I have been unable to post my project by attaching the file. I have sent the file to another member who is going to try and post it here so someone can take a look for me. I appreciate all the help!
                           Chris
#28
B2KMobile.EZB
Here is Chris's project if anyone wants to take a look at it.
The reason he couldn't save as a public file to the cloud is because he hasn't put the digital port descriptions in. I was able to save to the cloud privately, but can't help with the initial issue he was reporting because I don't have an EZ-B v4 yet. (well... I might be able to help. Reading the thread now to see if I have any input).
One suggestion to maybe help with your cloud issues is to temporarily delete the soundboard V4 control. It changes the file size from over 10 meg to just 168k which makes it easier to handle. Once you get your arms around saving and downloading from the cloud, you can edit it to put the sound back in.
I get the same warnings as you Alan... Deleting the soundboard allowed me to save the project to my cloud (private) with no further issues....
@Kamaroman68... Your project may be too big to save? Also, have you changed your user name or email in your EZ Robot profile lately?
#32
Hey Guys thanks for the help.... I will try later on tonight when I get home. I guess what I am missing though is I don't seem to be having a problem saving to the cloud (see post 21). I just cant seem to find it in the cloud. Unless the soundboard is causing that issue I believe the reason the file got so big was due to the addition of a second song I put on that I was fooling around with. I will try, thanks.
                                                 Chris
