EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Have you completed the tutorials in the LEARN section of the site? Are you using the example JD project which is installed? Are you using the latest version of ARC? Have you calibrated and fine tuned the servos? Is it that JD doesn't walk very well or that you can't even make him try to walk?
I did everything you mentioned except to calibrate the servos, how can I calibrate them? and yes, I cant even make him try to walk. thanks a lot, await your instructions Daniel
Go through all of the tutorials. Amongst them are some for calibrating JD.
hii again, i calibraited all the servos, but something else came up. When i'm connecting to JD to the computer, before i gave it any order it twists so fast that it pulled out some cabels... whats wrong here?
Daniel
  1. Are you using the latest ARC? When you load ARC, it tells you if there is a new version.
  2. Are you using the latest JD project that is included with ARC?
  3. When you connect to JD, he will lie on his back. Always lie the robot down or hold it in your hand when you press the CONNECT button.
@DanielKal you claim you have calibrated the servos however it shows that you haven't completed the tutorials in the learn section for calibrating the servos.
Complete this tutorial plus the 4 after it. They show, clearly and in depth, how to calibrate the servos.
Also the lesson DJ linked to for Connecting To JD
Completing the lessons in the Learn section will mean that you enjoy your EZ-Robot a lot quicker than if you do not complete the lessons. Even if you think you know what you are doing the lessons are a great help and should be completed if you wish to enjoy your robot.
I think a lot of people are doing the tutorials but neglecting to push the complete button. I think we'll see a lot of this. People just don't want to do things they are told to do or they just miss it in the excitement. I think this is especially true with young adults or kids. Too much like school.
