Sighthound Cloud API icon Sighthound Cloud API — Cloud-based detection of people and faces in robot camera video; returns locations, gender, age, pose, emotion, plus 68-point facial landmarks. Try it →
That's exactly what happened to me
To help me guide you without wasting time it helps to let us know which lessons are completed, this way we don't go around in circles and we don't need to repeat what is in the lessons.
When the example JD project connects to the EZ-B it moves to the "Stop" auto position, this will cause the servos to move however it should not be violent enough to pull any cables out, it certainly hasn't done this to me.
The lesson about connecting to JD explains how JD needs to be when you connect. Ensure you are doing this.
Ensure all servos are correctly calibrated and ensure that assembly is correct (paying attention to the orientation of the servos).
All of the above is covered by tutorials/lessons. To be honest there isn't much more to ask you to do to solve the issue.
If you have done the above then I must ask you the following to try and figure out what is happening.
When you click connect in ARC how do you have JD? Is he stood up, led down, in your hand, face down on the floor...
When you carry out Step 7 of the Lever servo Calibration lesson how does JD pose when assembled? Could you post a photo of your assembled JD after pressing the "All Servos Ports To 90 Degrees" button in step 7 of the lesson?
