PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Russia
version of my ez-robot v4
Did you try selecting then clicking the camera start button in the camera control?
I am having a similar issue. My web cam works fine. Click start and bingo. Not with the EZ-B camera. Blue light is on solid. Info at the bottom of the page reads.
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 8/26/2014 9:11 AM - Camera Disabled 8/26/2014 9:11 AM - Error Initializing Camera: System.TimeoutException: The operation has timed out.
any ideas?
go to devices and select the ezb camera from dropdown list. then hit stop and then hit start.
Been there and done that. Not working. I think the camera is defective.
@bookmaker32 Just a check here... The Video Device dropdown in ARC probably shows 2 different EZB:\192.... cameras. Make sure you have the correct one selected. It will be the one that matches the connection box 0 device ip address. Initially it would have been set to 192.168.1.1. Now it will be something other than that most likely.
If you have that correct and still dont see the camera, I would contact EZ-Robot support and have them check it out with you.
I am on the line with them as we speak.
Hey guys,
I'm not sure if this is the issue in this case, but when the EZ-B is connected via client mode you will have to enter in the new EZ-B IP address into the camera control. You won't need to keep the ":23" add the end
Here's an example:
Otherwise, in regular AP mode you can connect to the camera with the default "EZB://192.168.1.1"
