Wavefront icon Wavefront — Wavefront grid planner computes collision-free, deterministic paths from start to goal using known occupancy maps for indoor robots. Try it →
I guess I was right. EZ-B is sending a replacement. What a great company. Fantastic support. Thanks to the forum for all the help. It is so greatly appreciated.
Hi all!
V4 Camera was working, and now it does come on. Getting the following:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 8/31/2014 11:24 AM - TCP Server stopped 8/31/2014 11:24 AM - TCP Server stopped 8/31/2014 11:24 AM - TCP Server stopped 8/31/2014 11:24 AM - TCP Server stopped 8/31/2014 11:24 AM - TCP Server stopped 8/31/2014 11:24 AM - Attempting connection on 192.168.1.6:23 8/31/2014 11:24 AM - Connected to 192.168.1.6:23 8/31/2014 11:24 AM - EZ-B reports EZ-B v4 OS 8/31/2014 11:24 AM - Welcome to EZ-B v4 Beta! 8/31/2014 11:24 AM - EZ-B v4 ID: 60-54-0-0-47-255-60-57-57-38-38-38 8/31/2014 11:24 AM - Connected 8/31/2014 11:24 AM - Setting battery monitor voltage: 6.6 8/31/2014 11:24 AM - Setting battery protection: True 8/31/2014 11:24 AM - Setting i2c rate: 100000 8/31/2014 11:25 AM - Error Initializing Camera: System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.1:24 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult) at EZ_B.EZBv4Video.Start(EZB ezb, String ipAddress, Int32 port) at EZ_B.Camera.StartCamera(ValuePair videoCaptureDevice, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 320x240 8/31/2014 11:25 AM - Camera Initialized: EZB://192.168.1.6 @ 320x240 8/31/2014 11:25 AM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 8/31/2014 11:25 AM - Camera Disabled
Should I contact EZ-Robot Inc., for a replacement. Blue led flash at power up on Camera then it does not come on, after connected to network?
J
What IP address do you have set for the camera @Jdebay?
It looks like your EZ-B is 192.168.1.6 but the camera is set to look on 192.168.1.1. Change the camera IP to the same as the EZ-B V4
still does not, was working.
j
