UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Well I downloaded the sdk 1.20. It is not obvious how to install it.
Is that the version the plugin asks for?
If you extract the zip file that you downloaded, there should be a setup program to run.
Ensure to get a compatible version. The plugin specifies a version. Get the same version if you can.
There is only version 1.2 And I do not not see a setup file anywhere. there are no executable files. yes, I extracted all the files ,looked in every folder and directory.
Click on the version on the website. There are many many versions.
Ah, I put my glasses on and saw the itybity tiny arrow beside the 1.20.0. You must think me an daisy.
Thanks for your patience, I'll be trying the different versions if I can find an install file.
No problem - i don't think you're daisy. Oculus hasn't made developing for it very easy.
I hadn't asked this question yet - but, does your computer support the necessary hardware for virtual reality? Meaning, have you used the oculus with any games or programs? Some people have VR but their computer video card isn't VR supported.
