TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Here’s the instructions: https://synthiam.com/redirect/legacy?table=plugin&id=59
Which step of the instructions is causing a challenge? I don’t have a production rift, I have a dk2. So not sure what the differences are. Rift is a pretty complicated system to program for because they keep changing everything
Thanks you for replying DJ.
I have extended the desktop. I have the camera running and EZB connected.
Once I press attach in the plugin the program ARC crashes.
Darn - Oculus, that's not helpful at all:) Why did they go and do that...
I'll have to find some time and take a look at what they did to break it.
I haven't tried any. I really don't know how to get started with a SDK.
You just install the sdk like any program. That’s what is needed for the plugin to work - Because the sdk contains the drivers. There are different drivers for different applications.
