ESP32_MPU6050 icon ESP32_MPU6050 — ESP32/Arduino EZB firmware with MPU6050 support: provides accelerometer angles and Yaw/Pitch/Roll gimbal servo values for stabilization and scripting Try it →
#145
For the 2 camera idea, if you want to share trained faces between the cameras, the Omron support had this to say:
It is possible for customer to share album data between 50 degree and 90 degree type. But every time when customer enrolls person to HVC-P2, they have to select camera type and share album date (*I think he meant data) to another HVC-P2. Also, if the 50 degree HVC-P2 uses album data from 90 degree HVC-P2, accuracy might decrease. <<
So that is something to be aware of for anyone want to experiment with 2 cameras.
#146
Hello Justin!
Time is come!
I got some experiemtents with two omron cameras!
I have learned a lot about the two different versions.
I also made some Boxes for them. (I will post tonight)
I also see you write something new ( i must read now)
(Now i begin not with "I")
And i have a question:
How i can make a copy of David plugin?
I got everything (thats show a second Omron plugin - a second Control Command)
BUT.... The GUID is not working.
I copy a second folder with a "_copy" but if i load the plugin i got a message that the GUID is not valide! Please got a new one from EZ-Robot.
Do you know a solution?
Boris
#147
HI Justin.
NO it was old. Your Threath I know it.
I will check also the calculation stuff.
But there is still one problem:
What i will do with this lines where i don't have a Name and a "0"?
In my count function i can't count this lines!
How i can "leave aside" this lines?
Boris
#148
Hello Justin!
Forget the plugin!
I made a beta version and i got a new GUID Number!
And it works!
It's a little bit complicated with the order to connect the cameras to the PC with diffrent COM Ports.
BUT in the END i got TWO Cameras running (not at the same time - this will come)
with diffrent Albums from two diffrent folders ( because of two different albums ;-))
Now i must check how i can rename the variables:
Omron_Face_Recogition
"Omron_Face_Recogition_010"
then i can run this two cameras at the same time.
Then i can write a script:
" IF the Cameras check the age - i will have "Omron_age" and "Omron_age_010"
Now i have twice so much results in 10 seconds for the age and then i can make a calculation for the mid age and it will be perfect.
The same with genger and normal body or face reco.
YOU WILL SEE
Boris
#149
Hi Justin!
AND HI ANDY!
Sorry i forgot!
OK, back to Omron...
I found the Variables...
in "OmronHVCP_Plugin.dll" ...
i open it with visual 2017 basic but i can't really find now the variable and i can't change something.
mmmmm Here i could take a little bit longer.
Or someone an idea?
Boris
#150
Just got home. Hi Boris....
Two eyes, sounds good. I will be watching......
#151
HI Andy,
welcome home!
Until now the project goes fast on - i hope it will not stock with the .dll and change the variable names. But i am still on. I must understand how David write the .dll file.
In the end the plugin from David are 4 files (dll, pdb, xml and py ) and the album folder.
The hole rest from the plugin you can delete. The plugin will run without this hole files. But this 4 files the plugin need.
I also manage to make a copy of Davids plugin - so that i can run two Plugins but each as is own.
But later more.
Boris
#152
Sounds Good Boris. Good luck and thanks for the updates.
Ron
