Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
#161
Hi Boris, thank you for testing! That is exciting to hear my first plugins turned out well so far.
Your results for the values are interesting, I will take a look at that and see if I can find the cause. Thank you again!
#162
Hi Justin,
no Problem - it's my job to do that.
But cool, now with 2 Omrom and two Kind of values!
I will test more.
Boris
#163
HA! Good work Boris, sure enough, there was a typoe in the original source code from David where "hand" was typed in place of "face" for the variable. I want to try to add something else before I release a new update. Before I do....do you have any other ideas you'd like to see added?
#164
Boris or Anton, does Body or Hand detection ever return anything for you? Either with the Omron Evaluation software or in the variables in ARC?
Mine never detects my hands or body.
#165
Hello Justin,
i got values from Body and Hand BUT......
BUT.....
It not works everytime!
Normaly I must run the Omron original Software and then I can run the plugin in ARC and it works.
The same situation with the Name Reco.
On the next day, I start the computer and plug everything and start first ARC!
MMmmmm no working recognition... so i load the Omron original Software and check that the album is ok. In the Omron Software the Recognition works not everytime... so Ii had a look into my saved Album and then I go back to the video windows and suddenly the Recogition works! Then go to ARC and how wonder there also the Reco works.
And this I do regular!
Funny- its like that the Board must load again the Infos or the the Original Software make the Board load right.
It's stoopid, but it's feels like that. I mean it's not running with the first time- only after i check all in the Omron Software and go then to ARC ok.
But if i plug off and plug in the CAM it can be a problem - Then again the Omron SW and back to ARC.
BUT- this was also before with David original Plugin- so this has nothing to do with your update.
Boris
#166
Both the plugsins are fixed now for the hand/face coordX value swap. I also added a button on both of them to open the Omron Eval software directly so you don't have to hunt for the plugin folder. I also added a "FRA" only option.
#167
Hi Justin,
sounds cool!
I will check in some hours and will report you!
Boris
#168
Hey guys...I know I am a little late to join the party, but here I am!:) I set up the plugin and the camera today, I just had too little time lately to do any robotics, and it might stay that way for some time... But since @JustinRatliff made the magic happen and this threat is still evolving, I hope I can participate and also help testing the plugin!
I will do some further testing in ARC soon...I wanted to do this for quiet some time! This will be a lot of fun!:D
