Anyone managed to hook one up to the EZB yet ?............just curious.
nanomole40
— Edited
Single Camera Servo Server
— TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control
Thanks for the explanation.
Ron
Album path feature is added in the configuration menu of the plugins now. You must set a path.
I also added a "plugin folder" button because I'm always going to the folder and I'm lazy and I wanted a button so you all got a button too.
And I added Question Mark helpers to explain what the buttons are for and to re-iterate multiple time that the camera can NOT communication with both ARC and the Omron evaluation software at the same exact time.
I updated direction in the plugin download webpage too, as an FYI, because the webpage shows more details.
YOUR THE MAN ! What a nice Christmas gift. Thanks.
Ron
Hi Justin,
I set up the new plugin and saved a face. Everything is working again except the facial recognition.
The facial data is stored in the B5T-007001 folder in the 0 subfolder. Do I move this data somewhere else or copy it into the HVC-P folder?, also in the 0 subfolder? Do I set a path to the B5T-007001/0 ? As you know I am unsure in this area.
It sounds like I am still in the same situation as I was before the new (4) upgrade, but I know I am getting close.
Ron
No Ron, you do not need to "move" anything.
Everyone must set the album path in the Configuration settings. That is why the update was released so everyone can set their path now because of variations like yours, if you are not setting your path to your own folder where your actual album is then your face recognition will never work in ARC.
Configuration:
-You will need to configure for your camera for port, baud, Python folder and album folder for trained user faces. Once you save the configuration your settings will be saved for future use.
Ron your full folder path is probably: C:\Users\Public\Documents\EZ-Builder\Plugins\d42aefd8-17e4-470b-ae5a-fabdd747035d\EvaluationSoftware_rev.2.4.1\B5T-007001\0\RegistData
Here is a picture of my album path, you see the directory path is highlighted in the address bar. My trained user face folder 000, 001, 002 are visible in this folder.
Mine isn't working. I will continue to work on it using the info you have shown.
I don't know why my data isn't saving where I want it. I will let you know what is going on when I sort it out.
You need share screen shots Ron of where your album data is. Where ever your user.dat file (you can see in my screen shot where my master User.dat file is) is saving too, your camera itself picks that when you train user faces in the evaluation software. I think you are just confused on the folder path name.
I got it running with 3 faces.
The data is stored in the B5T-007001\0 folder.
I guess, like you said, each camera has it's own path for storage.
I had tried to assign the same folder as you did, but it wouldn't save to that location.
Later I may try to dump everything and start from scratch to see if it is ok. For now I want to play with it.
OOPS. I hadn't looked at the screen before I posted to see your message. Yeah, the camera does it's own thing
