Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
#209
That is correct, every Omron camera based on version/firmware might will create its own album path, you can't control that, you just need to know where it is. As long as you know "B5T-007001\0" is you path, and it works for you that is all you need. As long as it is working that is all that maters.
IF it is not working, post or send me screen shots please.
#210
Actually I previously used a poor choose of verbiage , its the camera firmware in conjunction with the evaluation software that picks the album folder that everyone has no control over.
If your camera is an original Omron HVC-P then you probably get a folder named "HVC-P\0\RegistData"
If you have an HVC-P2 the current version your folder so probably one of these "B5T-007001\0" "B5T-007001\0\RegistData" "HVC-P2\0\RegistData"
#211
Yep ! That is what I was chasing.
Quick update,
It is so cool to have Antonn tell me who he sees, especially when he says "I see Me."
I plan on programing in Santa Claus' picture, just in case !
Ron
#212
Hey guys...the new updated version of the plugin seems to be working just fine! But also I do have a problem when running the HVCP_1st_Test_Loop...
When I check on the Omron.exe I can see my name being displayed, but within ARC I am only getting the "I saw no one message"
I am writing my album the the ROM of my Omron camera, is that the correct approach?:)
@rentaprinta Ich meinte die Ausdrucke von Dir auf der Thingiverse Seite!
edit This is the album path that is save in the plugin C:\Users\Public\Documents\EZ-Builder\Plugins\d42aefd8-17e4-470b-ae5a-fabdd747035d\EvaluationSoftware_rev.2.4.1
#213
Hi Mickey666,
I think your path needs to extend further. I ended up using
\EvaluationSoftware_rev.2.4.1\0
Look at the examples Justin listed. You will probably find the one you need there.
Also you do not need to move anything. The camera firmware and software puts the facial data in the folder location, if I understand Justin correctly.
Ron
#214
@Mickey666Maus, Ron is correct. That is not your path, it is the start of a default path because something has to be stated in there. That's why keep trying mention over an over that everyone has to set their path.
If I remember Mickey you have an original HVC-P so your full path is like mine which is probably: C:\Users\Public\Documents\EZ-Builder\Plugins\d42aefd8-17e4-470b-ae5a-fabdd747035d\EvaluationSoftware_rev.2.4.1\HVC-P\0\RegistData
#215
Thanks...I will try that, sorry I did not have enough time on my hands. Otherwise I would have digged thru the thread more thoughtfully! I am positively sure everything will work just fine once I setup the path correctly!
Thanks for the wonderful plugin, and sorry about asking stuff which I should have figured out myself!:)
#216
@Mickey666Maus no worries. It was good feedback for me to see that having a default path in there can appear confusing. I had to release another update to fix some other issues related to how the variables are treated in ARC so I changed the default path to make it more clear that it must be changed.
Lets all make our bots smarter now with our Omrons. :)
