MP3 Trigger icon MP3 Trigger — Serial MP3 Trigger for EZ-B: plays MP3s from mini‑SD; configurable port/baud. Deprecated-replaced by EZB v4 streaming audio. 3rd‑party. Try it →
Correction. My board came from SparkFun not servocity.
@MovieMaker - I did see those at sparkfun and almost bought one. But after reading about these and the ability to go with either 5v or 3.3v out, multiple outs, and the price, I went with these. Now to see how well they work...
According to specs minimum input voltage is 9V... has anyone tried 7.2V?
Don't get this one if you are using a lower voltage..
This is a low drop out adjustable , use one of these. Or just use the correct resistor. You could do that too
Good call Josh, I do use one of these for all of my step downs to 6V for my servos.
Bret the best converter to use is a LDO regulator up to 10 amps ,3 pins easy to use and best part is much longer battery life
That type of converter has a dropout of 1.25 volts most LDO is .2 volts or less
I see alot of guys love to use DC-DC converter but they are not great for battery type toys or projects or meter ,they waste much much power ,plus cost is mostly higher
Only good about them is plug and play,just wire it up and its ready to go
Using LDO is has much less power lost,pretty easy to make ,small pcb and a cap and about $3 TOTAL COST
look at the EZB it doesnt use DC-DC converter for same reason and most LDO CAN TAKE UP TO 24 volts input
MOSTLY at work that what i do design Low battery circuits since almost every tester me make ONLY uses batteries,plus if you look at and battery type of product none ever usesa DC-DC converter for the same reasons
Can you please link us to this ldo
