Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Farnell UK - 3.3v Low Drop Out Regulators
They are what to look for. I'm sure searching a product code would bring up suppliers in your country. I have posted a small schematic for a 6v regulated supply using one somewhere, I'll see if I can find it shortly.
here is one link,there are many others at different outputs and current rating
and easy to find a lower cost also,this is 3.3 volts at 3 amps
3.3 volt LDO regulator
they are so simple to use most have 3 pins and use them like any standard regulator ,ones with 5 pins has a shutdown pin or flag
DIGIKEY IS A GREAT PLACE IT HAS OVER 42000 TYPES of LDO regulators
digikeY LDO REGULATORS
