Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Pwm Slider Question Pwm On D4 Turns D14 On And Off
I am finding PWM slider issues, here's one that I have posted in the cloud, (is this the proper way to request help?) When the PWM slider on d4 is moved up to 100%, d14 output goes high. Then when I slide the d4 PWM slider down to 0% d14 then output goes low. This happens across multiple software revs, board os and 2 different v3 boards. This can be observed by attaching leds to these ports. I am wondering is this the right place to point these issues out? If not please guide me, this forum stuff is new to me.
I'll take a look and see what's up:) That's a strange bug! I wonder what the heck could possibly be happening to cause that...
DJ, You are awesome. Thanks for looking into this. I have two ez3 which is really cool, its also great when you have any problems you can rule things out. On this problem I thought it may be due to my new 64 bit computer. So I ran the program on my old vista computer (running xp) and it had the issue there too. Good luck.
I was under the impression ARC wouldn't run on anything before Win7...So you had it working on XP?
@Richard , yes its my older computer that has an old version of ARC before it became unsupported. I keep it as a backup.
Wait, is this the latest version of ARC? Because the XP version should not be able to connect to the most recent EZ-B firmware.
Yes it is the most recent version on my new computer. On my old computer I would say it is probably a jan 2014 version and it connected and worked fine. I dont have the version number because I am not at home right now.
Wow, I don't know how you got any version from 2014 to work on XP:)
