Relative Servos icon Relative Servos — Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control Try it →
Pwm Slider Question Pwm On D4 Turns D14 On And Off
I am finding PWM slider issues, here's one that I have posted in the cloud, (is this the proper way to request help?) When the PWM slider on d4 is moved up to 100%, d14 output goes high. Then when I slide the d4 PWM slider down to 0% d14 then output goes low. This happens across multiple software revs, board os and 2 different v3 boards. This can be observed by attaching leds to these ports. I am wondering is this the right place to point these issues out? If not please guide me, this forum stuff is new to me.
Yes, it worked, I didnt do much but check that d14 issue. But I did not notice anything out of the ordinary. P.S. The version is 2013.07.03.00 on my old computer.
Is there a way that I can roll back the v3 os to a version that matches 2013.07.03.00 ARC? I cannot move forward due to the PWM issues. If I can roll the os back I will be able to continue until there is a fix. Thank you
I'm actually looking into it right now:) great timing
If it is affecting only D14.. Can't you just use another port or have you used all 20? I just tried and I can not replicate your problem... PWM slider on D4 does not change the high/low output on D14 on any of my 3 ezb3 boards... Could it be a wiring issue?
Solved it, I will post an update in a few hours for you.
Wow, I envision hours and hours of code to fix issues like this. You make it sound EZ:) I'll check it out as soon as I can. Thanks DJ
#15
PWM issues solved in latest release
#16
did you want to set this to resolved?
