Continuous Servo icon Continuous Servo — Control a 3-wire continuous 360-degree servo in ARC: adjustable forward/reverse speeds, start/stop buttons, board/port selection and test controls Try it →
France
Question With Ez-Bit Library
Hello, I have a problem with the ez-bit module to retrieve different stl files. He remains stuck on:
Downloading certified EZ-Bit list... 18 EZ-Bits indexed Comparing against your library... Download 18 EZ-Bits... (This may take a while)
1 of 18) Downloading Hexapod Body - Six v0.1 by DJ Sures (1 074 377 Bytes)
A review? Thx
Are you using the latest version of ARC?
France
Yes download yesterday .
Which OS? Win 7, Vista, XP, 8?
Update your .net framework to the latest.
There was a similar issue when the revolution version first come out but I was sure DJ solved the problem and it didn't need the .net fw updated.
France
Thank you for the support, I'm on Windows 8 and net framwork 4 is already installed and up to date ... sick
Does the green bar move at all? How long have you left it to download?
Uninstall and reinstall ARC?
I can confirm it works, I just removed Six's body from my library and re-synced perfectly fine.
France
Bar remains at bebut block 3 or 4% and for 30 minutes it does not move. I just uninstall reinstall, always the same.Scan for syncronisation works well, but the download... Server problem ?
It worked fine for me 20 minutes ago so the server is fine.
Check you have no antivirus or firewall blocking it.
France
ok i check thx
