Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
France
Question With Ez-Bit Library
Hello, I have a problem with the ez-bit module to retrieve different stl files. He remains stuck on:
Downloading certified EZ-Bit list... 18 EZ-Bits indexed Comparing against your library... Download 18 EZ-Bits... (This may take a while)
1 of 18) Downloading Hexapod Body - Six v0.1 by DJ Sures (1 074 377 Bytes)
A review? Thx
Rich, I see the library. But, I don't see the little EZBit item that has four screws to attach to any flat surface to start a EZ-Bit compilation. When will it be moved to the Library?
Thanks,
Mel
@Mel I have no idea, I'm sure the EZ-Robot staff will add it when they get chance.
France
Hi, always at the same stage, no possibility of recovering the stl files, ez-bit stuck at 2, 3% (control antivirus and firewall) test latop of my daughter in a hotspot, nothing ... The ftp server a problem with France:)
a another solution for download stl parts ?
Thx
Thingaverse wouldn't be a solution besides, are the EZ-Bits on Thingaverse?
@Romain, disable all antivirus and firewalls (note, some will remain active even when you ask for it to be disabled for a short time, check it is 100% off - google your AV software for help with that). Check your router to make sure it isn't blocking anything and try again. I can assure you there are no problems with the servers nor with your geographical location (we have other members from France who have the library up to date).
Unless DJ changed things (which I doubt) everything goes through port 80 and uses HTTP not FTP. There may be issues if the file extensions are unknown to your Security, firewall or router.
As stated the other day, I successfully deleted Six's body from my library and re-downloaded it therefore there are no issues with the servers. The issue will be your end, most likely due to anti virus and internet security applications running.
is there any tutorial on how to use the libary ? i see download/upload it say libary up to date but no stl's are seen in bit builder.
hi RR
yes i know this ,but then i have to copie one by one. can i upload or download the libaryall all at ones?
