EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
No, but you could write the robot functions you need with the UniversalBot SDK in C# and run it on a Raspberry Pi running Windows 10 iot Core.
ARC needs the full windows GUI. Windows 10 iot Core is just the operating system kernal. Basically designed for embedded systems that do one or two things, not a general purpose multi-tasking computer.
Thanks Alan. That clears things up a little.
OK, this looks like what I need. Was rather annoyed that everything's tethered, but I can toss Win10IoT onto a Pi and I already have C# mojo, so this will probably do the trick.
