Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
No, but you could write the robot functions you need with the UniversalBot SDK in C# and run it on a Raspberry Pi running Windows 10 iot Core.
ARC needs the full windows GUI. Windows 10 iot Core is just the operating system kernal. Basically designed for embedded systems that do one or two things, not a general purpose multi-tasking computer.
Thanks Alan. That clears things up a little.
OK, this looks like what I need. Was rather annoyed that everything's tethered, but I can toss Win10IoT onto a Pi and I already have C# mojo, so this will probably do the trick.
