Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
Rgb Led Help Needed
Rgb Led Help Needed
Hi everyone, im having a great deal of trouble trying to sync 2 of the RGB leds i have for my robots eyes.
Just spent the last 2hrs, and some other days trying to get them to sync, so i thought it best i turn the ezb off and ask for assistance because its greatly delaying my current project...and meanwhile giving me zero confidence to start the next project for if i can't sync 2 leds... tired
Ive been close with it, but then they stray off and start to do their own thing, no matter what i do i just can't get them to join in holy matrimony.
Any help would be greatly appreciated, ive spent around 3-4 hrs total trying to figure it out as embarrassing as it is for me to say..and the more i try it seems to all go backwards and becomes much worse than when i started.
if you want blink two common anode rgd leds at same time:
# rgb 1 led pins
$rgb1_red=0
$rgb1_green=1
$rgb1_blue=2
# rgb 2 led pins
$rgb2_red=4
$rgb2_green=5
$rgb2_blue=6
$active=false
:loop
  if ($active=true)
    # orange
    pwm($rgb1_red, 100-99)
    pwm($rgb1_green, 100-64)
    pwm($rgb1_blue, 100-0)
    # orange
    pwm($rgb2_red, 100-99)
    pwm($rgb2_green, 100-64)
    pwm($rgb2_blue, 100-0)
    $active=false
  ELSE
    # off
    set($rgb1_red, on)
    set($rgb1_green, on)
    set($rgb1_blue, on)
    # off
    set($rgb2_red, on)
    set($rgb2_green, on)
    set($rgb2_blue, on)
    $active=true
  endif
  Sleep(500)
goto(loop)
#18
edited my incorrect post. Missed the difference in the two diagrams and mixed up cathode and anode terms.... For something so simple, it sure does get complex.....:)
someone told me all leds have diff speeds. you have to by a bag full leds and look for the 2 that have desame speed.
#20
@nomad
What? In what way?
when they change color from full leds.
#22
I think @Nomad is talking about self-cycling RGB LEDs. They are never the same speed from one to another. They are bit analog that way.
@Nomad 6R, Plain (diode only) RGB leds don't have speed.
RGB led is a single component, but the reality are 3 different leds in a single container.
Not all leds are equal, so is important to check the led details
RGB led example:
All the 3 leds share the same forward current 20 ma with a max of 30 ma (before blowing up)
Different colors = Different wave lengths
Different colors different forward voltages, this means in similar conditions the brightness will be different.
ohm law: I = V/R
R = 330 (builtin EZB/Iottiny resistor)
I (Red) = (3.3 - 2.0) / 330 => 3.93 mA I (Green/Blue) = (3.3 - 3.2) / 330 => 0.30 mA
This means Red will be more bright than Green and Blue
jeremie yes i didn now the name of these leds.
php learn some again.rgb have no speed.
