TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Rgb Led Help Needed
Rgb Led Help Needed
Hi everyone, im having a great deal of trouble trying to sync 2 of the RGB leds i have for my robots eyes.
Just spent the last 2hrs, and some other days trying to get them to sync, so i thought it best i turn the ezb off and ask for assistance because its greatly delaying my current project...and meanwhile giving me zero confidence to start the next project for if i can't sync 2 leds... tired
Ive been close with it, but then they stray off and start to do their own thing, no matter what i do i just can't get them to join in holy matrimony.
Any help would be greatly appreciated, ive spent around 3-4 hrs total trying to figure it out as embarrassing as it is for me to say..and the more i try it seems to all go backwards and becomes much worse than when i started.
@Nomad 6R stop calling me php:)
anyone has a link for the tri color rgb led whit flat head? i want to rebuild robosapien v2 to ezbv4.
#28
I recently tried the 4 pin cathode led, but they ended up being worse than the other ones i was using, i couldn't even get them to cycle, so i'm just going to run a single led for one eye now.
I wanted the eyes for emotion, red for anger, green and blue for whatever, but i'm now stuck with red only..so red it is and red it has to be.
These leds have been the bane of my existence so im moving on.;)
tomy
you can,use a pwm for each color.
#30
@Nomad,
thank you i wish i had of known that earlier..now its a little too late, his head has been painted and i put the factory eye piece back in so i just use the one LED.
Not what i wanted but it will have to do.;)
For the style of head it is, the one led for his eye will actually suit better.
I'll make sure for the next robot that i build will have all 3 colors sync for 2 eyes. I'll need to do that for little Robi, thats a must.;)
tomy
we will get there some day.
howmany volts do the rgb leds have to be to use on the ezbv4 ?
#32
3.3v i think, not exactly sure Nomad.
Should get my volt meter out.
Hey Nomad...with the 4 pin led...do i need pwm to actually cycle them from red to blue to green?
So they don't random cycle like the 2 pin cathode's?
That just dawned on me, for me when i powered them on they just stayed red and never cycled.
