PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
Robot Does Not Work
Something is wrong. when i connect ez-b to computer it gives me two ports COM3 and COM4. But on tutorial video shown COM3 and COM7. I connect to COM3 as it is shown in video. When i try to open examples botton it does not give same window as shown in video. (picture attached) In this window i cannot open calibration example project. It just not there. If i just go to Add-servo-modified servo Movement Panel and start to modify servos it works (sometimes) or led on ez-b and bluetooth turns of and servos start shaking. sometimes one arm goes up in the air,sometimes head while leds are off. and it goes up or down not smooth, it shaking, like moving mm by mm and i have to disconnect all servo leads from ez-b to stop them shaking. if i just reconect power it keeps shaking. what is going on?!
The interface is a little different from the videos now. I'm new and had some of the same issues with finding things. I don't know why your bot is cracking out but I know the shaky servo movement happens when you have the servo set to a low speed. I just discovered this today. Also if you try to turn a servo too far it will vibrate as well. You can hear it hum. I'm short on time now but someone will be able to help you better. I'll check back in tomorrow to see if any of my newbie experiences may still be of some help.
when this happens and one or more servos start shaking, leds on ez-b go off. when i reconnect power they stay off until i unplug all of the servos leads from the board. Somebody please help me!
Thank you for information...!
try removing the EZ-B from the bluetooth control panel and re-installing it again. The COM will be different from the tutorial base on how many bluetooth device you have connect in the present and in the past.
If you have ever connected a Bluetooth device your computer may show completely different com ports but there are usually two only one port apart. Choose the lower of the two ports to connect.
Can you take pics of your setup and tell us about your equipment you have hooked up. I hate to hear you are having strange issues with things freaking out.
Thank you guys for your help. i will make video today or tomorrow of all proceses that going on when "this" happens. So you can see how Walle is shaking and ez-b LEDs go off
Today i tried to deleted ez-b bluetooth connection and reconnected it again. I open ez-b softwear and start adding and configuring servos. so first i do with left and right wheels. they work fine. i can control them with arrows on my pc. (but if i press arrows too fast, LEDs on ez-b go off and one of the wheel servo starts shaking. when i reconnect servos leads to ez-b and start configuration again-it works). Then i configure vertical and horisontal servos. and they work fine too till some point. then ez-b LEDs go off and one of the arm's servo starts shaking (but i have not even configured them yet, but they are connected to ez-b board). And how do i add arms servos? I dont see them in that section where the rest of servos controls are.
This is video where Walle is shaking: https://www.youtube.com/watch?v=j_Ysjfx6kik&feature=youtu.be
I use Sony laptop and external bluetooth device because this pc does not have one buit in.
It could be your power supply. have you tried using batteries yet? If your P.S. is not 12 volt 5 amp, you'll have problems. No lights and slow motion leads me to believe its not getting enough power.
