Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Robot Does Not Work
Something is wrong. when i connect ez-b to computer it gives me two ports COM3 and COM4. But on tutorial video shown COM3 and COM7. I connect to COM3 as it is shown in video. When i try to open examples botton it does not give same window as shown in video. (picture attached) In this window i cannot open calibration example project. It just not there. If i just go to Add-servo-modified servo Movement Panel and start to modify servos it works (sometimes) or led on ez-b and bluetooth turns of and servos start shaking. sometimes one arm goes up in the air,sometimes head while leds are off. and it goes up or down not smooth, it shaking, like moving mm by mm and i have to disconnect all servo leads from ez-b to stop them shaking. if i just reconect power it keeps shaking. what is going on?!
#17
OK Dj. I am watching your video about MP3 trriger when you are typing in new voice recognition command. But quality of the video is poor and since i am new in programming i cannot do anything because i dont see what you do in that video. Dont see what are you typing, is it , between words or . ? Please!
#19
this is crazy. i dont know what to do. please,somebody explain what is going on? confused
There is a lil switch next to your head phone jack on the MP3 trigger. Switch it to USB. And see if that helps.
#21
And i was wondering what is that switch for? thank you! I will try
Let me know if that works for you.
#23
yes.thank you. it worked. omg,so easy things,but if you are new they are not easy at all. thank you very much.
Anytime. In glad to help.
