Vader Sentiment Analysis icon Vader Sentiment Analysis — VADER sentiment analyzer for ARC returns positive, neutral, negative percents and a compound score from text; enables emotion-driven behaviors. Try it →
Simply fabulous, great color. I like the wheel chair base who makes it and what is the model number. Also just out of curiosity, how long will it run and how long does it take to charge. Sorry for all the questions but I really like your disign.
Ireland
Thanks all Video to follow testing mindwave headset at present will forward specs later today
@bravia did you paint that case to match? That's awesome. So what is the beacon for? Is this a outdoor robot or indoor? Is the beacon used for the robot to "see" which direction home is? I'm just curious how you are utilizing it. I have several IR sensors on the back of my robot for the future use of backing up to a charging area by my desk following a single IR beacon.
Waw ! Congratz, a very impressive robot. Can't wait to see more of your work ! Keep it coming !
Ireland
Re Beacon First of all the Beacons works in pairs, one is fitted on Leonardo and I hold the second one so the Robot will track my location ,eg I remain stationary and say the "left sensor" on robot detects IR the robot will turn left , once the "front sensor" detects IR the robot will move forward
Take a look here it explains how it workshttps://www.pololu.com/catalog/product/701
Re colour Its the original CTM Power Chair model HS5600
Specs (original) Travel Range 25 miles 2 x 12 volt batteries charging takes 2-3 hours,but I never fully discharge
Ireland
#15
Some internal circuits
Note EZ-B is not connected as second EZ-B on dome is used for test easier to access, eventually this card will operate all functions. I intend to possibly place the chair back on the base and have a wii strapped on ones arm to move forward reverse left & right. But can' wait to integrate the Mindwave Headset .
#16
WOW bravia very cool on mindwave headset ,i have one plus EPOC headset,second on the pololu beacon i am designing one the same as pololu only using the EZB as the processor.
