Robot Leonardo under construction
A motorised wheelchair base it incorporates the original motors and the joystick controller.
Its design allows components to be removed so that modifications and tests can be carried out quiet easily.
Programming With Pictures
— Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots.
Wow Bravia - that is one hot looking 'bot! Can you imagine when we can 3D print robot bodies like that. Thanks for breaking new robot ground.
