Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Running A Led Of Port D6
Hey guys.
I have a couple of general questions regards running LED's off a digital port.
  1. I hooked up a 3V LED to the signal and ground pins on D6 on my v4 earlier today, made a little digital on, sleep 5 seconds, digital off script to test it but all it would do is very quickly flash once. I changed it over to port D12 and it worked fine. Any reason why D6 didn't work? The port is fine as I tested it with a servo. I was just wondering if it's because D6 is also a UART port as well and this may have caused the issue.
  2. Any ideas if I could power a set of 20, 3v fairy lights off the V4 signal and ground pins? I lent my multi meter out so I can't test the amp output of the LED's. They normally run off two 1.5v AA batteries. Could 20 bulbs be too much?
Thanks.:)
#17
Lol, sorry I'm confusing myself now:P. Let's try again.
Rich mentioned using the Vcc pins with a TIP122 circuit which will allow me to use the 5 amps from the Vcc pin. What I wanted to confirm was that using a regulator, that would have to be 5 amps too. For example, the 5v regulator from the shop only supplies 1 amp and would not be sufficient. Is that right?
I have two sets of 20 bulb LED strands, one is 3v and the other is 4.5v. I'm only looking at using one of these.
#18
It depends on the current draw of the LEDs. 1A will drive 50 x 20mA LEDs (1A/0.02A).
The regulator can be whatever you need it to be. You can't have too many amps but you can have not enough. A 1A may do but it will depend on the current draw of the LEDs.
#19
The Tip circuit is more or less just a switch.... It probably has a limit to how many amps can be pulled through it, but I don't think we're talking about any number we need to worry about... I have a 12V high output 24 super bright led array that only draws about 200ma (at 12V).... So I think your led light strip is probably going to be in the same neighbourhood... So I would have to say the voltage regulator from the store would be fine... So your light strip is 5V meant for an RC controller? You can also do the same with a LM7805 voltage regulator....
#20
No, the "light strip" I'm referring to are the battery powered Xmas fairy lights. Anyway thanks for explaining and clearing that up guys. I've been testing things in a couple of the spare ports on K-9's EZ-B. I'm ordering a new one at the end of the month and my new project will be using pretty much every available port (digital and analog), so not much room for error.
Thanks again Rich and Richard.:)
#21
No worries Steve.... If you're curious you could pull out the ole' multimeter and see how much the light strip is pulling in the way of mAs..... The higher the voltage the less power the strip will use (mA wise).... So I would try and use the max voltage that the strip is rated for... if you can that is....
#22
Yeah... multimeter. Sore point with me at the mo. I lent it to a friend "for the evening" over a week ago. Still waiting for it. mad
#23
@Richard.
Hey, you mentioned about using a relay switch like the one you linked to and I just found this on Amazon. I just wanted to ask about hooking it up. I get the Ground, +5v and signal in the right, but what are the terminals on the left (NO, COM, NC), and to which ones would a need to connect a two wire LED string?
#24
NO = Normally Open (i.e. when the relay is not powered/the EZ-B isn't set to high) the contact is open COM = Common NC is normally Closed (i.e. when the relay is not powered/the EZ-B isn't set to high) the contact is closed.
So, you would have your Vcc to Com. The LED, light, motor whatever connected to NO and the other side of it to ground. When the signal pin of the digital port is On/High it would close the contact and whatever is connected would work.
If you wanted it to work when the EZ-B signal was low/off (including if the EZ-B is powered off) then connect between Com and NC.
