Running A Led Of Port D6
Hey guys.
I have a couple of general questions regards running LED's off a digital port.
  1. I hooked up a 3V LED to the signal and ground pins on D6 on my v4 earlier today, made a little digital on, sleep 5 seconds, digital off script to test it but all it would do is very quickly flash once. I changed it over to port D12 and it worked fine. Any reason why D6 didn't work? The port is fine as I tested it with a servo. I was just wondering if it's because D6 is also a UART port as well and this may have caused the issue.
  2. Any ideas if I could power a set of 20, 3v fairy lights off the V4 signal and ground pins? I lent my multi meter out so I can't test the amp output of the LED's. They normally run off two 1.5v AA batteries. Could 20 bulbs be too much?
Thanks.:)
#25
A bit more info/diagram for clarity;
The switch in the relay is moved by the electromagnet from NC to NO when the relay is energised.
#26
Quote:
the other side of it to ground
Thanks Rich. Just to confirm from what you said, the other side (LED wire) goes to a ground on the battery. So this doesn't need a common ground then?
EDIT: Forget what I said about common ground. I'm going to power the LED's (with a 5v reg) from spare ground and Vcc pins on a port which a ping echo uses.
Thanks again buddy.
#27
If you ask Jeremie - he can help you with a mosfet schematic that can connect to the PWM of the ez-b and give you brightness control:D
#28
Thanks DJ. I may just do that.;)
#29
As I recall those relays need 5V to operate and the EZ-BV4 is 3.5V. You will require a converter like a EzSBC.com LS1
#30
@bookmaker32
Indeed they are 5v. I'm going to power it from spare ground and Vcc digital pins through a 5v regulator (post#27). Thanks though.:)
#31
Here's the thread that I believe @DJ is referring to. P-Channel FETs are used for switching/dimming the positive voltage side. But as the other folks on the forum have suggested a TIP high current transistor would work, or an N-channel MOSFET (for switching the negative side of the LEDs) would work as well.
@Bookmaker32 funny enough some relay coils will still respond to a lower voltage. I remember switching a 9V relay with 5V in the past.
#32
Thanks Jeremie. I'll take a look.
