Conversational Menu icon Conversational Menu — Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back. Try it →
You can connect to a different power source, the only thing to remember is to use a common ground.
Great, thanks. That's the same as Arduino then.
can you explain how to common the ground?
A common ground is when all grounds are joined together, therefore common.
The easiest method is usually to link all grounds of the batteries/power supplies together.
Like in this diagram
All ground connections are connected at some point throughout the circuit.
