EZ-B V4 Info icon EZ-B V4 Info — Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control. Try it →
You can connect to a different power source, the only thing to remember is to use a common ground.
Great, thanks. That's the same as Arduino then.
can you explain how to common the ground?
A common ground is when all grounds are joined together, therefore common.
The easiest method is usually to link all grounds of the batteries/power supplies together.
Like in this diagram
All ground connections are connected at some point throughout the circuit.
