Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
Oh my! I will take a look at it tonight
Hello!
I looked at the command, and I can not duplicate the error. The command appears to work fine. Reference the script help along the side for the command example...
Set (digitalPort, [on/off])
Set a digital port state to either on or off
Example: Set(D2, OFF)
Just tried it again and it works now?
It's a simple piece of code to switch the Omnibot eyes on/off when you pass near his ping sensor
Ping_Wait(D2,D3, lower, 30) set(D12,on) set(D13,on) Ping_Wait(D2,D3, Higher, 30 set(D12,off) set(D13,off)
Repeat on
Perhaps it was the previous ARC ver which I can't test
Thanks for looking:) :)
