Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Yup, I followed the tutorial step by step. Thank you for the advice, I will do that.
Hi
I am author of the plugin I will update it in some days due to synbot framework updates and new features in progress
I just need some tests and tutorial updating
hope you can test it deep in some days
I would gladly do some testing for you. I am sure there are others who would help with the testing also. Just post when the new version is ready for testing.
Hi
New version of Synbot plugin is on line with tutorial updated and Example JD Synbot on EZ Cloud.
Don't hesitate if you have questions or problems ..... Version 2 with some new learning capabilities will be ready in 3 to 4 weeks.
Jean Luc
Jean Luc, Can the SIML project be ether a classic or modern or does it have to be a classic? Thank you Richard
@ Jean Luc I can not get the bot to respond correctly.
This is the Syn Bot Window
Do not forget to Save Context when you decide to stop the chat with the bot
Otherwise all new bot learnings will be lost
Bot initialized for user id Jean luc
welcome to synbot Maya : hi i'm maya i'm an humanoid robot but how do you want i call you
richard Maya : what a wonderful name i will call you richard richard : how are you Maya : i can't answer
Must be a configuration issue but I can not figure it out.
I have saved the SIML project to C:/users/richard/UNAS/SynBot. So that folder has the UNAS.simlproj file and a directory named UNAS IN that directory is the Settings folder and the Templates folder. This is also where I copied your SIML files and is the folder I set in both of the directory settings on the config page of the plugin.
Hi
I think i have not included in the example files the how are you pattern so it is normal and bot reponse when it dont Know the input pattern is set to i can't answer Bot can only respond to user inputs if the corresponding pattern is included in the siml files the same Way all aiml software You can include this new pattern in siml files I Will send you to morrow example in order to react to the how are you input
Look at the test unit files included with the plugin and at the tutorial to discover more
Happy you test the plugin ....
