Connection Diagnostic icon Connection Diagnostic — Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support. Try it →
#25
I just test on another PC
I publish a V6 without change It seems that V5 was not correctly uploaded as some of the DLL was older one and the version release was not correct
After updating the plugin, you can verify in folder C:\Users\Public\Documents\EZ-Builder\Plugins(GUID) where GUID is the plugin GUID (The last modified) the plugin.xml file
it must be in version release 6
<?xml version="1.0"?>
-<PluginV1XML xmlns:xsi="https://www.w3.org/2001/XMLSchema-instance"; xmlns:xsd="https://www.w3.org/2001/XMLSchema">;
<FRIENDLY_NAME>Synbot Plugin</FRIENDLY_NAME>
<DLL_FILENAME>SynbotPlugin.dll</DLL_FILENAME>
<AUTHOR_NAME>Jlucben</AUTHOR_NAME>
<LICENSE_URL>https://synthiam.com/tutorials/plugin-license.aspx</LICENSE_URL>;
<PLUGIN_GUID>eae7154f-c1e0-4e41-a661-bc4d7fc66e90</PLUGIN_GUID>
<CATEGORY_TYPE>Artificial Intelligence</CATEGORY_TYPE>
<DESCRIPTION>Plugin interfacing with the SynBot Bot Solution</DESCRIPTION>
<VersionRelease>6</VersionRelease>
</PluginV1XML>
Germany
#26
Hi jeanlucben, Today I have installed your plugin and it works very well. With SynBot Studio I will now try to make extensions for the German language. You did a fantastic job! Thanks a lot for this ! I hope you continue your development at this plugin and we can look forward to new versions.
#27
Thanks joki
After some travels , I am beginning to work on a new version. If you find bugs in the current version , I will be pleased to fix them. I think some are remaining ......
Jean-Luc
