PWM Servo Feedback (I2c) icon PWM Servo Feedback (I2c) — Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining. Try it →
Stl Needed
hi all
is there anyone that can make me an stl file,the cost here in belgium to make an stl,is very high+cost material and chipping.also you dont get the stl file, companies says its there property.you dont have to do it for free ,but i , dont want to spend to much on it.
what do i want is a hip case ,similar like the neck part jd,but for 2 big servo's. the ones we use here ,lever servo's.color case is white.i want to give jd , some freedom more ,to be able take side steps.
the servo's comes together with no end piece where normal a screw sits. on top servo,here are some pics.
thank you
I'll work on the project tonight and publish the files with the project...
Thanks! you have another watcher waiting!
What kind of printer you use, and software ?
that is really awesome.are you doing the side steps too?
thank you
It appears that that improvement gives him a more natural walk. Love it.:)
i see you didn use cubes ? but made cross bracket.
woohoo awesome great thank you .
i have to mention when you cut the male off and i wanted to put a bolt&nut on the bracket.so i draw a cross to find the middle off the male,and i dril, a tiny hole in there for the bolt&nut,what i didn saw was the little wall, under in the middle male part.so my drill whent eacther left or right. so the hole was not in the middle,many thanks for the bracket with, female .my friend is allreddy printing.
