Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
Stl Needed
hi all
is there anyone that can make me an stl file,the cost here in belgium to make an stl,is very high+cost material and chipping.also you dont get the stl file, companies says its there property.you dont have to do it for free ,but i , dont want to spend to much on it.
what do i want is a hip case ,similar like the neck part jd,but for 2 big servo's. the ones we use here ,lever servo's.color case is white.i want to give jd , some freedom more ,to be able take side steps.
the servo's comes together with no end piece where normal a screw sits. on top servo,here are some pics.
thank you
i think dj gonna surprise us,new update ARC.:)
#26
Next need is a two axis waist. and more powerful servos.
or the backpack for jd from anthony.
#28
Watch the way you walk in a mirror Your waist twists you hips. The movement is complex but you can get more of a walk gait with a waist added. This walking will make you crazy... LOL
i notest to get a robot on one leg ,you start with the otherfoot lift outwarts, that puches the robot into the direction off the other leg you want him to stand on. ones you see he's going that way,take over with the foot also lift outwarts, you want him to stand on.
#30
Thank you for the nice design... is there an action implented in roboscratch?
Tnx Eddy
@DigiEddy are you happy with your Flashforge Dreamer ? Do you use a different software ?
digieddy
nice work.
