ADC Meter— ADC VU meter displaying 0-3.3/5V as a 0-255 linear meter; configurable board/port, sampling interval and color; pausable real-time readings.Try it →
A new EZ-B will have the name EZBv4 and part of it's MAC address at the end. You will need to rename the EZ-B v4 to what ever you want it to be using the Web Server
You can find out more how to use the EZ-B v4 in the LEARN section tutorials. Here is a direct link to the EZ-B v4 tutorials: https://synthiam.com/Tutorials/Course/5
Nomad, that isnt the IP. It is the SSID. When you connect to this with your android or iphone, you will be able to put it on your network. From there you scan for the IP that was assigned to this device.
It has been a while, but you have done this a few times before.
To receive assistance, these questions must be answered.
is the battery on the robot fully charged?
does the ezrobot make a startup sound when powered on?
is there a light flashing on the ezb when powered on?
what color is the light on the ezb?
are you connecting the phone/device to the wifi network of the ezb?
Press the connect button.
If an error appears, some devices take up to 1 minute to detect the ezb - wait 5-10 seconds and press connect again.
*Note: do not change or modify the IP address field on connection screen. Use the default value.
if a connection still does not occur, does the ezb wifi name display as the connected wifi network on the connection screen?
have you double checked the wire connections to the ezb using the very helpful learn section on our website? Ensuring the black wire if all plugs matches the black side of the ezb connections? Etc...
When resetting, does EZ-B speak introduction message as in the video?
If still unable to connect, notify EZ-Robot with the answers to these questions. Also provide what device is being used to connect to the EZ-Robot? (model/operating system) eg Samsung Note 3/Android, iPhone 6
its all starts to come very confusing.
thanks
It looks like this one has the entire MAC address instead of the last 4 digits of the MAC address in its SSId.
Should still work fine, an SSID is an SSID. Nothing special about the digits.
where do i find the ezb then?
Connect to the ezbv400078033cd1c network and the IP will be 192.168.1.1, just like always with a new EZ-B.
i cant get in 192.168.1.1 with android or iphone4 s
Relevant Mobile App Tutorials
Here’s the tutorial for the EZ-Robot Mobile: https://synthiam.com/Community/Tutorials/60?courseId=6
Here’s specific instructions for connecting SIX to EZ-Robot Mobile: https://synthiam.com/Community/Tutorials/51?courseId=6
Both can be found on the Activities tutorials: https://www.ez-robot.com/Tutorials/Course/6
Connecting Debug Procedure
Resetting tutorial link: https://synthiam.com/Community/Tutorials/16?courseId=5
