Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
when i connect with iphone led is red blinking
I have 2 of those EZB4's with as Allan says has the entire Mac address.... They work as usual.... no problems or issues whatsoever....
it connect for 5 sec green led flaching then red blinking.
i try them bolt,no luck its like post#12
i dont see the ezbv4 number.
here a video how it looks.
Okay, now I see what is happening....
Your network is setup to only allow certain mac addresses to be able to connect to it. This was because you had jerks for neighbors.
It is seeing your network fine but is unable to get connected because the mac address hasnt been specified in your wireless access point (Engenius). let me see if I can find the thread from the last time you had a new EZ-B.
#15
@Nomad.... are we going to do this every time you buy a new ezb4? Did you type in your network name and password before you pressed connect? It won't connect unless you spell your wifi network and password correctly?
