Personality Forge icon Personality Forge — Adds a Personality Forge chatbot to ARC, giving memory, emotions, AIScript dialogue, persistent conversation IDs and speech/chat integration via API. Try it →
Streaming Audio From Other Program Through ARC
Hi all,
Has anyone been able to Stream audio triggered from other programs through ARC over wifi to an EZB? I know the PC soundboard will play sound files located on your laptop. But what I want to do is play audio on an EZB that would normally play through my PC's speaker. For example maybe an internet radio show, a youtube video audio track, sound files triggered and used by another program on the laptop other then ARC.
Thanks in advance. :)
Hi Dave - that may be a feature request or plugin. The WASAPI can be used as input for something like the microphone control. I'll think on it.
Thanks DJ. Wish I knew how to write plug in or even what would need to be used to make this work.
I just finished publishing a plugin to relay sound to EZB.
@DJ: it's my first plugin i think i missed some point, the zip contains the DLL but ARC can't load the plugin, do you know if there are logs to help troubleshoot the issue ?
Thanks
I solved the issue, compilation issue (Debug vs Release).
Please let me know if it works for you.
Oooh:) fancy! I'm excited to try it out.
I just messed with this plugin. Really cool PTP, and useful!
@DJ,
Please try, there is a glitch every time (red light) between the PlayData actions, i tried different methods, but no success, i think i'll need an aditional PlayData method to allow adding data to the current EZB .NET Stack PlayData Buffer.
If you have time i can open & share the code in Github to improve the Plugin.
@David does it work ?
I trusted some old code from an old project (Broadcasting music to multiple wifi ARM/Arduino Clones), then i spent a couple nights porting to an ARC skill plugin, and then i crossed the fingers:)
It worked well. There was some lag issues where the audio cut out for a few seconds but nothing too annoying. Played youtube audio from a web browser through the EZ-B V4 speaker.
