Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Streaming Audio From Other Program Through ARC
Hi all,
Has anyone been able to Stream audio triggered from other programs through ARC over wifi to an EZB? I know the PC soundboard will play sound files located on your laptop. But what I want to do is play audio on an EZB that would normally play through my PC's speaker. For example maybe an internet radio show, a youtube video audio track, sound files triggered and used by another program on the laptop other then ARC.
Thanks in advance. :)
#41
I assumed you still wanted the ability to have other PC sounds from the PC, which is why I suggested the USB card and discussed using Windows 10 mixer to select which apps use which device. If you want all sound to go to the EZ-B, then yeah, just plugging in a disconnwplug, either unwired or just cut off an old headset (careful not to short the wires) would work fine.
Thanks Alan and everyone else. You all have been great help. I would have been stuck in the mud without you all. :)
#43
Quote:
I solved the issue, compilation issue (Debug vs Release).
@ptp hello, I am having the same issue. I did the steps in the tutorial but I didn't find the plugin I made in the ARC add controls window. How did you solve it?
#44
You’re missing a step in the very excellent tutorial: https://synthiam.com/Tutorials/UserTutorials/146/1
One of the steps I assume you’re missing could be:
  1. output of compile not being put in the plugin folder with folder name of your guid
  2. plugin.xml not being copied to output folder
  3. plugin.xml not containing the dll filename
