Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
avery window has a gear icon you can click on.there you type what you are looking for.excample i used servo.there is also a cheet scheet where you can find , you own poses or sound you made.
red under lined is how you must wright it in left side of the script
#106
@darticus.
If you add a script control to your project, or any control that has a script editor, there is a script menu in the right hand side that explains what each script command does. I have also posted the script manual here on the website...
EZ-Script Manual
#107
Very good! I see what your saying. I need something new to try! Again all Thanks Ron
#108
@Daticus Glad to hear you thngs are going well for you. One thing that would help on our end though is if you would put the screen name of the person you are addressing at the top of your post so we can tell to whom you are directing your comments. And perhaps be a bit more specific. For instance when you said Fantastic! It all worked exactly correct! what were you referring to?
At first I thought you were talking to someone named Ron since there is no comma or line feed between the word thanks and Ron.:)
#109
Sorry WBS00001 I will try to remember. You must be an English Major. Thanks!
Another question- When we program in script on the computer is this info sent to JD's memory through wireless communication when we hit save? Anyone know how this works? Thanks
#110
@darticus tsk tsk.... somebody hasn't been reading the tutorials... :) You should know by now the ezb4 is not an arduino... all code remains and runs (in real time) on your PC or mobile device... The ezb4 is just a puppet ... It executes commands sent to it over wifi from ARC or mobile device in real time... When you click save it just saves your script on your PC... when you hit save in the menu, you save your entire project to your harddrive.... or the cloud server...
#111
Richard R OK got it, I guess JD is useless without the computer on. Can JD run a program without your computer on? Now what would be the difference between running windows 8.1 and running an Ipad with ARC? Just learning sorry.
#112
@darticus... No... the ezb4 needs to be connected to a pc or mobile device at all times... It does not run code on it's own... That's why the ezb4 can do so much. The PC does all the work...
Quote:
OK, I guess JD is useless without the computer on
So is an Arduino and every other micro controller based robot.... Unless of course all you want to do is to follow a line or run around trying not to bump into things, then you're golden with an arduino.... Any robot worth anything uses the power of the PC in one form or another... The future of robotics is PC based... Micro controllers (for robotic use anyway) are quickly going the way of the dinosaur...
