Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
darticus
pics or chort video can be helpfull. you mean the dean connector?
#130
The brain as you call it should not fall out... After fixing the screw if it's still loose in the base do the mini deans pin adjustment (see my link above)...
#131
Thanks Richard R its fine now. Ron
#132
Nomad 6R The deans plug was pushing in but tightened the screw inside and all is good. Thanks Ron
daricus
great to hear.
#134
Now that its workable I turned JD on and his servos went all out of line and he would have fallen if I wasn't holding him. Where do I look now? Do I unscrew all servos to zero them in or is there another method. Are there settings I need to check somewhere to get him set before fine tuning? Thanks Ron
did you callibrate all servo's
#136
You need to go through the JD tutorial. The servos may need manual calibration, certainly need software fine tuning, and JD should always be powered on lying down. All of this is covered in the tutorial.
