EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
Hey Nomad. Sorry you're having trouble again. Hasn't this happened to you a few times before? Is this time simular to thouse times? What did you do then?
If you're useing client mode check the usual, IP address, signal strength. Can you power cycle the router and try to reconnect? Is the ezb showing up in the client list of the router?
When my ezb won't connect and the red led is flashing it is because of a comunacation error. I tried to send a command through the Uart port without starting it first or a bad serial command. Restarting the ezb usually clears it.
Nomad, the "ezbv4" starts speaking with an actual message that relates to the question. Do not ignore what the ezbv4 is speaking.
it does averything normal untill the voice starts speaking,then it goes over the, limit time out and stops connecting.i dont no why.it happens avery time, i want to connect an ezbv4.i dont find the answer there what the ezb says. i connected perfect on the EnGenius and then it dont connect thru my iphone. this way off connecting is a real pain in the A... its always something that doesn work or need to correct.avery download.
Nomad, the "ezbv4" starts speaking with an actual message that relates to the question. Do not ignore what the ezbv4 is speaking. What is the ezbv4 speaking?
welkom to the revolution visit www.ez robot.com
If the light is flashing red, there must be another message at the end... Such as "I'm unable to connect to your network". Please do not leave out important messages. Ezrobot has spent great effort to make spoken verbal messages and tutorials to assist with connecting.
Sounds like you pressed the reset button, connected in adhoc to ezb, configured client mode with incorrect parameters, and now it is unable to connect to the network.
The solution is to press the reset button, connect in adhoc mode, configure client with correct parameters, and use the network scan tool to discover the ezb on the network.
@Patrick, don't forget that you have MAC address filtering turned on in your router to keep the hackers out. You will need to add the MAC address of the new EZ-B to the filter for it to connect to your network.
alan
i started with that.i have to put it in engenius.that when good,but it did not connect. i think the engenius is smiles up.i cant get on the web page of engius.
