RGB Animator icon RGB Animator — Create custom animations for JD Humanoid's 18 RGB Eyes LEDs via I2C - per-LED color frames, transitions, pauses, scripting and real-time preview. Try it →
alan
am not sure if he knows this stuf.what do you think is wrong?
#26
I think your AP has been hacked and will need a factory reset and then lock it down before one of your jerk neighbors hacks it again. All of your EZ-Bs will need to be reset and re-added to the AP and it's MAC address filter.
Not too hard to do, just with your memory and limited English I think you would have a difficult time doing it yourself, and would be hard for me to help you remotely.
just try it in ap mode eather pc says cant connect or the ap doesn do any. yes i now its almost impossible to help remotely, is ezbv an incomming pc or outgoing,just saw firewall blocks all incomming.
how do i find a port number off a router.? and where to ad it on pc. i can see the ip number on my iphone and also router port.
#29
Not sure what you are asking. Are you talking about the firewall exception list?
EZ-B's use ports 23 for EZ-B control, 24 for camera, and 80 for the web page.
i added the ip from engenius to firewall,i found that. also i found and added to my internetconnections. so whats left is the webpage it wont open.from the engenius.
#31
Nomad, when you type in engenius's IP address into your browser trying to get to it's web page, do you get to see the Engenius log on screen at all?
no only when i put the cable in the laptop and use the default ip from engenius. withs is 192.168.1.1
