EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Turning Digital Ports On/Off With Speech?
Hello all When I'm using a Movement Panel the digital ports work (using "set digital" to verify, it turns red when off and green when it's on) but somehow when I try to use speech control to turn the same port on, it doesn't work.
Can someone test this for me, or is this a possible bug?
Thanks all.:P
I just tried set(d19,off) for an LED I have with voice rec and it worked ok. Is that what you were asking? Is it recognising your voice command?
hmmm ok That's what I was asking but it's not working for me...yes it is recognizing my voice command...let me try again
Nope didn't work. I also put SayWait("it's working") right after, and SayWait works but the digital port does not turn on...very weird
Are you writing the code as
setdigital(D#,On)
Or
set(D#,On)
It's the second one that worked for me.
Im using the second one.
Here:
set(D1, ON) sleep(250) set(D1, OFF) sleep(250) set(D8, ON) SayWait("I am turned on")
Nothing happens but the "I am turned on" part:D
Maybe put a sleep() in between the last digital command and the say"" command to see if that makes a difference.
Try increasing the sleep commands to 1000 .... they may be happening so fast you wouldn't be able to perceive the on/off transition....
Nope same thing. I'll try another computer when I get home.
