MP3 Trigger icon MP3 Trigger — Serial MP3 Trigger for EZ-B: plays MP3s from mini‑SD; configurable port/baud. Deprecated-replaced by EZB v4 streaming audio. 3rd‑party. Try it →
Turning Digital Ports On/Off With Speech?
Hello all When I'm using a Movement Panel the digital ports work (using "set digital" to verify, it turns red when off and green when it's on) but somehow when I try to use speech control to turn the same port on, it doesn't work.
Can someone test this for me, or is this a possible bug?
Thanks all.:P
#25
Strange. I'm running out of ideas now. So the script runs ok on its own without voice recognition, correct? Are you running the script in the voice rec control as a script block, or a ControlCommand() in the phrase configuration?
In post #6 you posted a script you was using. Have you tried a simple set(D8,on) on its own in the script in the speech rec control?
#26
@Doombot you need to remove the quotes from "1" and "0"...should be
if(getDigital(D8)=1)
saywait("it is working")
elseif(getDigital(D8)=0)
saywait("it is not working")
endif
#27
  1. Are you having trouble with D8 only?
  2. Is your SET(on) and set(off) working for other ports?
Richard is correct, "Quotes" are for "Strings".
String A string consists of alphanumeric characters to create words. "This" is a strong. So is "This". And "This is a string containing a sentence".
Example: $x = "This is a string"
Numbers Numbers are simply numeric. A number is a 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 only. The only additional symbols you can use for numbers are a - (minus) and a . (decimal)
Example: $x = 3.14
#28
@Dj
I just got home and tried it. Everything I did in the beginning worked, I just needed the EZb to be connected...very weird but it works.
@Richard R and @Dj Thanks! I'm sure I know that (by now) I was just beat and I forgot...but thanks for the correction kind sirs.
On to testing! To those who care I'm just finishing up the cosmetics on my bot! Mechanically it's sound and ready to kill!
:D
#29
Sounds like you may have it sorted then. Looking forward to seeing the end results of your bot.:)
#30
@ Doombot
Hi, Any pictures yet? The weather is getting nice, so I can't wait to see him by the Harley..
What was the final script you ended up with?
Ron
#31
Doombot did this ever get completely resolved? I'm having very similar issue.
#32
@ANDY ROID
Those are just test scripts, but I do use a lot of set() commands since I use a lot of motors and tip120 circuits...so i turn on/off digital pins a lot...
Oh no pictures just yet...
@kamaroman68 No it was resolved on it's own, since the test scripts i wrote worked when the EZb was connected...it wasn't working when the EZb is NOT connected. I don't know why...but instead of giving credit to anyone I just left it unresolved. What issue do you have? Maybe I can help...
