Shortcut Creator icon Shortcut Creator — Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation. Try it →
Uart Terminal Display, Can't See Last Line
When using UART 0 Serial terminal to read ASCII output from the Roomba diagnostic tests, as each test is printed out, the last line of text cannot be seen at the bottom of the terminal screen. It would be helpful if the screen could keep the output ASCII data above the bottom of the terminal screen.
I'm unsure what you mean? Can you be more specific please
As each test is printed out and displayed on the terminal screen, the last line of text is below the displayed text box.
oh! Thank you for the screenshot - that makes a world of difference! i'm on it:)
One workaround solution could be done using an EZB-Script command to clear the text displayed on the screen just before the next test is requested. Would that be possible?
Or wait for the next update:). But 100 points for a creative idea!
Update should be tomorrow
WHoo Hoo, Thanks DJ nevermind then, I'll wait
forgot to mark resolved in my excitement.......
Bump, DJ is this still on your list for the next update ?
