EZ-B V4 Info icon EZ-B V4 Info — Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control. Try it →
Uart Terminal Display, Can't See Last Line
When using UART 0 Serial terminal to read ASCII output from the Roomba diagnostic tests, as each test is printed out, the last line of text cannot be seen at the bottom of the terminal screen. It would be helpful if the screen could keep the output ASCII data above the bottom of the terminal screen.
It is done. Was it not in the last update or has the last update not been finished yet? There's a hundred things on my plate so the last update might be the current update.
It's held back from the request for the brookstone rover 2 support. It has taken a lot of time.
I certainly understand the full plate DJ. Just checking status.
