Unable To Open Project
I just tried to open my project and I get a Windows error box on the screen saying "Unable to load project. Object reference not set to an instance of an object". So then I tried to load it from the Cloud and I get the same thing. I have a gazillion hours in my project and I can't imagine it all for not.
Upload your project (on the right of the reply box is attach file, use that to upload it). DJ may have time to check it out, if not or in the mean time I'll take a look at it.
Have you try to uninstall and reload ARC?
Junior.EZB Here is a copy of the file. I have restarted my computer and reloaded ARC.
I am having the same error message when trying to load your project on my laptop windows 8.1 Your file looks corrupted, do you have any backup/ older version of it to try on ?
Hopfully DJ or someone would be able to open an edit it
How many controls should the project have?
Looking at the project it seems like you only have the Interface Builder and the Sound Servo. Yet the interface builder shows controlcommands to scripts which are not in the project file...
By removing the sound servo control manually (not with ARC) I can get it to load however all it loads up is the interface builder. Is this correct?
If not, do you have a back up of one with more in it? The save file doesn't contain any EZ-Scripts or any other controls.
DJ may be able to see more than I can since he will understand more of the save file than I do so wait and see if he can do anything before writing it off.
But from what I can see in the save all that's there is the interface builder (with all buttons set up to ControlCommand() scripts etc.) and the sound servo. Removing the sound servo from the project will make it open again.
I've attached a "fixed" version of all I can salvage. Again, wait to see if DJ can do more.Junior-635458720809126250-noss.ezb
I will wait for DJ and I sure hope he has some magical cure. I guess worst case is I will just have to type it in again. The cloud file must update with the local one because they both are that way.
