Autonomous AI icon Autonomous AI — Autonomous AI robot skill with vision, speech, movement, animations, and self-directed task execution powered by LLMs. Try it →
Unable To Open Project
I just tried to open my project and I get a Windows error box on the screen saying "Unable to load project. Object reference not set to an instance of an object". So then I tried to load it from the Cloud and I get the same thing. I have a gazillion hours in my project and I can't imagine it all for not.
A little late and not much comfort but always keep backups.
I keep 2 older versions as backups for all important projects. For instance I have MelvinA, MelvinB and MelvinC. I'll open the latest, say MelvinB, save as Melvin C (which is the oldest of the three) and that way I'll have at least 2 steps backwards in case of problems like this one or in case I accidently delete something I needed.
You can try starting with a empty project and merging your project one part at a time. Hope that works for you. That is what I had to do.
I just noticed something. The file that is saved on my computer looks bad but the one on the Cloud looks okay. It is still corrupt when I try to open it. Sorry to say it is set as private but maybe DJ could access it. If so there is still a chance it may be okay.
Well here I go again. I downloaded the latest ARC (after deleting KB2918614 again) and now my new program won't run. Once connected the program freezes. I tried someone else's and it seemed to work. Here is a copy. Junior2.EZB
here is the debug report:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 9/13/2014 4:32 PM - TCP Server stopped 9/13/2014 4:32 PM - TCP Server stopped 9/13/2014 4:32 PM - TCP Server stopped 9/13/2014 4:32 PM - TCP Server stopped 9/13/2014 4:32 PM - TCP Server stopped 9/13/2014 4:33 PM - Attempting connection on 192.168.0.3:23 9/13/2014 4:33 PM - Connected to 192.168.0.3:23 9/13/2014 4:33 PM - EZ-B reports EZ-B v4 OS 9/13/2014 4:33 PM - Welcome to EZ-B v4 Beta! 9/13/2014 4:33 PM - EZ-B v4 ID: 25-54-0-0-47-255-59-57-59-37-37-37 9/13/2014 4:33 PM - Connected 9/13/2014 4:33 PM - Setting battery monitor voltage: 6.6 9/13/2014 4:33 PM - Setting battery protection: True 9/13/2014 4:33 PM - Setting i2c rate: 100000 9/13/2014 4:33 PM - Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.EZB.(Int32 , Byte[] ) 9/13/2014 4:33 PM - BbytesToExpect: 5 9/13/2014 4:33 PM - a Received: 9/13/2014 4:33 PM - Disconnected 9/13/2014 4:33 PM - Disconnected
It's not easy for me to access it but I can sure take a look to try.
#15
Is this it?
Virtual Desktop #1
Virtual Desktop #2
That seems to be it DJ... Works fine on my PC (no freezing)....
