Upgraded firmware. Now won't connect.
I must be doing something wrong. it said that it upgraded fine. I updated the ARC also.
Stumped!
Midi Control
— MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes.
Stumped!
yes, during the connection attempt, mine keeps pulsing, then it holds for bit n then the notice showes up saying it could not connect.
I have tried on both new project and loaded, same story.
What bout the red led, what does it do?
it flickers before attepting a connection, then while connecting it lights up constantly a while till i get the notice that it could not connect. it starts flickering again.
Hmmmmmm let me see if i can somehow replicate it. I'm sitting in front of many boards with no issues. I'll try a few things. Be back in a few
Alright, thank you.
I have tried Everything. I have uninstalled and reinstalled booted up turned off. No luck so far.
Do we have a new release or what???????? I hooked up my newer board, which I've never connected yet. It booted up just fine. It told me right away there was an update available. I downloaded the update with no problem. I wanted to update ARC also but when I clicked on the download button I got an error message that said the page had moved. The one thing I was really looking for was the new "Servo Speed" control. It does not show up in the manual; nor does it appear when I click on "add an control", servo",etc. Have you done the new release DJ? I also tried doing a script with " ServoSpeed(D1, 50) " No change in servo speed; still moves very fast! I'm still seeing firmware version 15.2.
oh!oh! I think someone made zee boo boo. But, we are all human. Well, except for my Robots. But don't tell them that.
the main problem I have is that I cannot upgrade the firmware again because I cannot connect up to the Bluetooth.
We will be patient.
Mel
